Activity Forums Adobe After Effects Expressions Setting a min length while using sourceRectAtTime
  • Setting a min length while using sourceRectAtTime
    Posted by Kristjan Erusk on January 19, 2018 at 2:25 pm
    Hello everybody.
    Is there a way to set a minimum length for a shape layer while having it change length according to a text layer?
    E.g. Length = y but not shorter than x
    It would look something like this.
    And the other question would be if i have two shape layers that both change their length depending on text layers 1 and 2(with the sourceRectAtTime expression) then can I have shape layer 1 always be longer than shape layer 2 regardless of the length of the text?
    Kristjan Erusk replied 8 years, 7 months ago 2 Members · 2 Replies
  • Kevin Camp
    January 19, 2018 at 11:01 pm
    you can use a Math.max() function… it would allow you to select the greater value of either A or B…
    say you had this:
    A = 100 ;
    B = 20;
    Math.max( A, B )
    it would return 100, since 100 is larger than 20.
    so if you had this:
    A = 100 ;
    B = sourceRectAtTime().width ;
    W = Math.max( A, B )
    if B was less than 100, W would equal 100, if B was greater than 100, then W would equal B
    Just FYI, Math.min() works the same but returns the smaller value.
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Kristjan Erusk
    January 21, 2018 at 1:30 am
    Thanks, this worked perfectly.
