Activity › Forums › Apple Motion › Set XY of filter by tracking data
  • Set XY of filter by tracking data
    Posted by Peter Silie on August 19, 2017 at 2:15 pm
    I found a filter for “bulging” (sorry, I have only the german version and don’t know the original english title). The setting of center XY location should be set by tracking data. I created a tracking analysis on the video to get the path of moving of the object, but I don’t know how to connect/bind it to the center location of the filter.
    Is this possible at all?
    Thanks in advance
    Dirk
    Peter Silie replied 9 years, 1 month ago 2 Members · 4 Replies
  • Mark Spencer
    August 19, 2017 at 3:17 pm
    Yes – add the track parameter behavior to that parameter then set the analysis data as the track source.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Peter Silie
    August 19, 2017 at 3:38 pm
    I think I didn’t get it. On the filter itself I could not add the Motion tracking “change” behaviour. When droping it onto that filter it is inserted below in the same group but not under the filter. There are several other filters assigned to that clip. But only that single filter should change its center possition accordingly to the Motion Analysis data.
    Where do I have to move and drop which item?
  • Mark Spencer
    August 19, 2017 at 9:06 pm
    Mark Spencer
  • Peter Silie
    August 20, 2017 at 9:10 am
    Aaaahhhh! Thank you!
