Activity Forums Adobe After Effects Expressions Set wiggle value to drive text layer?
  • Set wiggle value to drive text layer?
    Posted by Mike Douglas on February 7, 2017 at 1:35 am
    Hi there, I’m building a fake user interface. I have 2 circular rings that I’m revealing with Radial Wipe – see attached image (each ring is separate and would have its own value).
    I have a Wiggle expression on the Transition Completion, and I was hoping to use that value to drive a text layer – to type out the current percentage of the ring that’s visible. Is there a way to do this with an expression?
    Just a note that the Transition Completion is the opposite of the number that I want to display (eg: if the value is at 80, then the number I want to display is 20, so I guess that’d be 100-[value]). Thanks very much!
    Mike Douglas replied 9 years, 7 months ago 2 Members · 4 Replies
  • Dan Ebberts
    February 7, 2017 at 1:47 am
    I think you’ve nearly got it. I’d start with something like this:
    100 – thisComp.layer(“Circle 1”).effect(“Radial Wipe”)(“Transition Completion”)
    Dan
  • Mike Douglas
    February 7, 2017 at 1:52 am
    Nice! Thanks again Dan. I’ll give that a shot. Didn’t realize you could reference layers like that. I assume I’d plug that into the Source Text for the text layer. Cheers!
  • Mike Douglas
    February 7, 2017 at 1:57 am
    OK, just tried it and that works perfectly. Thanks again!
  • Mike Douglas
    February 7, 2017 at 2:02 am
    Oh, and I added a Math.round so it didn’t return ridiculously long numbers:
    100 – Math.round(thisComp.layer(“circleL2”).effect(“Radial Wipe”)(“Transition Completion”))
