Activity Forums Adobe After Effects Expressions set up the expression rotation
  • set up the expression rotation
    Posted by Sara Morini on May 25, 2015 at 7:56 pm
    Hello,
    I am new in after effects. I am following some tutorial where clicking on “rotation” should appear a bar where you can type the code, like: time*150….when i click on the circle near the word rotation, that bar doesn’t appear to me. Do you know why and how can do to show it? Thank you very much!!
    Sara Morini replied 11 years, 3 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 25, 2015 at 9:20 pm
    You need to alt/opt+click the property’s stopwatch (like creating a keyframe, but with alt/opt).
    Dan
  • Sara Morini
    May 28, 2015 at 9:03 pm
    Thank you very much, it works but now i have another problem. when i apply to a layer the cc radial blur effect, there is a square created where the edge of the effect ends. so basically the radial is cut in a rectangular shape. t Do you know how fix it? i read to download a plugin (grow bound) but i can’t find it anywhere…do you think you can help me somehow? thaaaank you 😉
