Set Up HD Project as SD, how can I save?
So, I shot a short in the HVX-200, DVCPro50 HD, 720p format. I ended up importing the files in the standard def. DV-NTSC 48k setting. I didn’t realize what i did and edited all the way into a fine cut before realizing nothing being exported was HD. I’ve since created a separate DVCPro50 HD project, but am looking to avoid a way of going from project to project, recutting in all the shots. Is there a way around this? Thanks.
-Matt
