Activity Forums Adobe Premiere Pro “Set to Frame-size” or “Scale to Frame-size”
  • “Set to Frame-size” or “Scale to Frame-size”
    Posted by Tom Laughlin on October 17, 2014 at 4:07 am
    I’m editing a 1080p timeline and adding some pics that are big and b-roll from shutterstock that’s 720p. I’ve been using the set to frame-size usually. Is this ok!? It makes the pics and b-roll shots fill the screen but does this affect the quality? I’m up-ressing correct? And with the pics, I’m down-ressing, correct?
    Tom Laughlin
    Producer/Editor
    Digital Chop House
    Salt Lake City, Utah
    http://www.digitalchophouse.com
    Dennis Radeke replied 11 years, 11 months ago 2 Members · 1 Reply
  • Dennis Radeke
    October 17, 2014 at 11:33 am
    [Tom Laughlin] “I’ve been using the set to frame-size usually. Is this ok!?”
    Yes, Premiere Pro has a very good scaler and does a good job of preserving detail when upscaling.
    [Tom Laughlin] “It makes the pics and b-roll shots fill the screen but does this affect the quality?”
    Yes, theoretically. But you’re not changing the size so much that viewers should notice. Also, with “Set” to frame size, you are not rasterizing the larger images, so you are preserving the original resolution, so really the answer to your question is no – no change in quality
    [Tom Laughlin] ” I’m up-ressing correct? And with the pics, I’m down-ressing, correct?”
    Anything bigger than 1080 is downrezzing
    Anything smaller than 1080 is uprezzing.
    Dennis – Adobe guy
