Activity Forums Adobe Premiere Pro set to frame size global command
  • set to frame size global command
    Posted by Tony Wise on February 20, 2015 at 7:35 pm
    Hi there,
    Want to work with 6k footage in a 1080 timeline. I do not want to select the pref. “scale to fit” because I want to maintain the resolution once in the timeline. The “set to frame” option is great. Problem is I don’t want to have to right click and select “set to frame” every clip I put in timeline. Is there a way to globally do that within the project similar to how “scale to frame” pref. works? Thanks.
    Tony Wise replied 11 years, 6 months ago 1 Member · 0 Replies
  • 0 Replies
