Activity Forums Adobe Premiere Pro Set to frame size but fill composition frame entirely…
  • Set to frame size but fill composition frame entirely…
    Posted by Iacopo Boccalari on January 18, 2017 at 10:43 am
    I’m editing some r3d footage shot in 3k, 4k and 5k and my final output will be @1080
    I added all of my footage to a timeline and I quickly want to scale it so I can see the full image, so I use set to frame size, but this results in top and bottom black bars.
    Let’s take 4k for instance: it was shot at 4096×2160 which is wider than 16:9, so premiere’s set to frame size results in a scale factor of 46,9, I’d rather have it scaled by 50% making it fill the frame entirely and knowing I still have some room on the sides.
    Is there a quick way to do this? I really don’t wanna go through all the clips manually entering the scaling factor…
    Thanks in advance!
    Iacopo Boccalari replied 9 years, 8 months ago 2 Members · 2 Replies
  • Jeff Pulera
    January 18, 2017 at 3:12 pm
    Set scale for one clip, Copy, then multi-select other clips and use Paste Attributes
    Jeff Pulera
    Safe Harbor Computers
  • Iacopo Boccalari
    January 18, 2017 at 3:56 pm
    Yep, that’s what I ended up doing.
