Activity › Forums › Adobe After Effects › Set Render Engine Setting As Default
  • Set Render Engine Setting As Default
    Posted by Joseph Wilkins on April 6, 2010 at 5:31 pm
    So I created a new preset for my preferred render setting, but cannot figure out how to set it as my default, so I dont have to select it from the drop down in the render queue every time I render..
    Can anyone help?
    Cheers
    Erik Waluska replied 16 years, 5 months ago 3 Members · 2 Replies
  • Walter Soyka
    April 6, 2010 at 5:36 pm
    Add an item to the Render Queue, click the triangle next to “Render Settings,” and then click “Make template.”
    From that screen, you can select what the default render settings are for each render type.
    Walter Soyka
  • Erik Waluska
    April 7, 2010 at 12:18 am
    The shortcut is to just hold down Ctrl (Cmd – mac) as you select the preset from the drop-down menu, which makes that preset the default.
    -E
