Activity Forums Adobe After Effects Expressions Set position to composition
  • Set position to composition
    Posted by Victor Ribbs on June 19, 2020 at 8:30 am
    hello,
    I dynamically add compositions (as_msg) in a basic composition (as_comp)
    var comme_comp = app.project.item (1);
    var tels_msg = app.project.item (2);
    I tried to assign positions to each tels_msg but without success. I manage to move the layers contained in tels_msg
    thank you
    // \COMP BASE
    var tels_comp = app.project.item(1);
    // \COMP MESSAGE
    var tels_msg = app.project.item(2);
    function addMsgs()
    for ( i = 0; i < tels_data.length; i++){
    var _layerCollection = tels_comp.layers;
    var msg_instance = tels_msg.duplicate();
    //var msg_instance.name = "MSG_INSTANCE_"+i;
    var msg_layerCollection = msg_instance.layers;
    addAvatar(i, msg_layerCollection.byName("AVATAR_SHAPE"));
    addInitialName(i, msg_layerCollection.byName("AVATAR_INITIAL"));
    addName(i, msg_layerCollection.byName("SEND_BY"));
    _layerCollection.add(msg_instance);
    Victor Ribbs replied 6 years, 3 months ago 1 Member · 1 Reply
  • Victor Ribbs
    June 19, 2020 at 5:51 pm
    hello,
    I found the solution to my problem.
    the last layer added to layers is always linked in 1
    var msg_position = tels_comp.layer(1).property("ADBE Transform Group").property("ADBE Position");
    function addMsgs()
    var nL = 1;
    msg_position.setValue([x_pos, y_pos]);
    nL++;
    y_pos += 120.0;
