Activity › Forums › Adobe After Effects Expressions › Set multiple value's on multiple times without keyframes
  • Set multiple value's on multiple times without keyframes
    Posted by Yvonne Van de kop on February 23, 2022 at 8:56 am
    Hi there,
    Sometimes I need to make animations without using keyframes and it always works fine with the linear expression if I need only 2 value’s at 2 times. Hope that makes sense…
    In this case it’s specifically about Time Remap. The idea is really simple but I just can’t get it right. The result must be like this:
    At frame 0 > Time Remap at 0
    Second frame controlled by slider > Time Remap at 181
    At frame 250 > Time Remap at 200
    The first value and the last value I can set with keyframes but I’ve no idea how to add the middle value at a time controlled by a slider.
    Anyone?
    Yvonne Van de kop replied 4 years, 7 months ago 2 Members · 2 Replies
  • Tomas Bumbulevičius
    February 23, 2022 at 9:30 am
    Hey Yvonne, its as simple as making if/else statement in timeremap.
    Pseudo code as follows:
    if (frame > 0) {
    //do your interpolation
    } else if (frame > 250) {
    } else {
    //set default values when condition is not met or is in between, if needed
  • Yvonne Van de kop
    February 23, 2022 at 2:36 pm
    Solved it like this now. Don’t know why I didn’t think about the if/else statement haha
    var Dur = comp("00 MASTER CONTROL").layer("MASTER CONTROL").effect("Duration endpage")("Slider");
    var AS = framesToTime(0);
    var AE = framesToTime(181);
    var AC = framesToTime(200);
    var OP1 = linear(time, 0, Dur, AS, AE);
    var OP2 = linear(time, Dur, 10, AE, AC);
    if (time < Dur) {
    OP1
    } else {
    OP2
