Activity › Forums › Adobe After Effects › set end point of layers?
  • set end point of layers?
    Posted by Scrimshaw1803 on May 24, 2006 at 5:05 pm
    If I change my comp length from 30 seconds to 60 seconds, is there a shortcut key to automatically set all layers in the comp to extend their out point to the new end of of the comp without time stretching any keyframes?
    I know I can select all layers and drag their endpoints, but I;d prefer a fast keyboard shortcut for this.
    Enzo Tedeschi replied 20 years, 4 months ago 2 Members · 1 Reply
  • Enzo Tedeschi
    May 24, 2006 at 10:56 pm
    Go to the last frame of your comp (or wherever you want the layers to end). Select all the layers you want to extend, then left Alt + ] to extend / trim. Left Alt + [ will trim / extend from the start of the layer.
    Note: This will only extend as far as there is footage in the layer to accomodate i.e. You cant extend a 30 second video clip to 60 seconds if your source video clip actually only goes for 30 seconds. You’ll need to loop in that instance.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
