Activity › Forums › Adobe After Effects Expressions › Set Distortion mesh value of Mesh warp effect by script
  • Set Distortion mesh value of Mesh warp effect by script
    Posted by Vitaly Balikov on June 6, 2019 at 4:30 pm
    Hello guys,
    I am trying to drive Distortion mesh value of Mesh warp effect by script:
    but last line get error: Can not get or set a value from this property….. This propertyValueType CUSTOM_VALUE has not been implemented.
    I can’t believing… It so sad….
    Is there way to drive by distortion mesh by script or expression?
    Please help
    var comp = app.project.activeItem;
    var layer = comp.selectedLayers[0];
    var effects = layer.property("ADBE Effect Parade");
    var eff = effects.property("ADBE MESH WARP");
    var DM = eff.property("ADBE MESH WARP-0004");
    var va = DM.value;
    Filip Vandueren replied 5 years, 3 months ago 3 Members · 3 Replies
  • Jacob Resch
    June 1, 2021 at 9:36 am
    Hey Vitaly,
    did you find a solution to this? Having the exact same problem. Or i also want to drive the distortion mesh with expression.
  • Filip Vandueren
    June 1, 2021 at 1:10 pm
    The only thing you can do with expressions of custom properties is valueAtTime();
    The only thing you can do via scripting is apply Animation Presets, there’s no access to the actual values inside those properties.
  • Filip Vandueren
    June 1, 2021 at 1:11 pm
    Sometimes you can get away with doing the effects with the bezier warp effect, those parameters are all just 2D positions and can be easily adjusted with scripts and expressions.
