Activity › Forums › Adobe After Effects › Set data rate in Media Encoder, CC version on Mac OS X
  • Set data rate in Media Encoder, CC version on Mac OS X
    Posted by Sean Platt on May 15, 2014 at 6:37 pm
    Hi. Is there a away to adjust the data rate in Media Encoder? I have been looking but have not found where. I am relatively new to After Effects/Media Encoder. Using CC version. Is the target bitrate where this is taken into account? I need to have a data rate of 200 kbps. I have the target bitrate set to .2 mbps. When I open mp4 in Quicktime after rendering and look in Quicktime Movie Inspector, the data rate is between 300 and 500 kbit/s. I am not savvy when it comes to rendering so reaching out to see how I can adjust data rate in Media Encoder. Thanks!
    Sean Platt replied 12 years, 4 months ago 2 Members · 4 Replies
  • Walter Soyka
    May 16, 2014 at 1:04 pm
    You are setting the target bitrate correctly — but that low target may not be achievable with the other parameters you’ve set, including raster size and frame rate. Can you post a screenshot of your encoder settings?
    Walter Soyka
  • Sean Platt
    May 16, 2014 at 1:25 pm
    Thanks Walter. I have attached a screenshot below of encoder settings. The pixel dimensions were determined by the client who also requested datarate at 200 kbps. These are 1 minute animation videos (all illustrator art imported into After Effects) set at a frame rate of 15 for the web. H.264 format.
    screenshot:
  • Walter Soyka
    May 16, 2014 at 8:10 pm
    Is the audio contributing to your higher data rate?
    Walter Soyka
  • Sean Platt
    May 17, 2014 at 2:17 pm
    Hi Walter. the client specs were for the audio to have a bitrate of 32 or 48. When checking Quicktime movie inspector, these 1-minute animation videos I am working on with audio bitrate set to 48 have a datarate of 410 while videos with audio bitrate set to 32 have a datarate of 390- both of which not close to the datarate of 200 also in the client specs.
    As I alluded to earlier, I am fairly new to After Effects and hard time wrapping my head around rendering options. I use quite a bit of time remapping throughout these 1-minute videos. A lot of mini animations built as layers in Illustrator and brought in to After Effects where they are timed with audio (time-remapping) to look like a classic simple cartoon. No effects. Just flat color illustrator art. Just throwing that out there in case it might have bearing on the datarate (guessing not but fishing for answers ;))
