Activity Forums Adobe Premiere Pro Set clip in point numerically using frame numbers
  • Set clip in point numerically using frame numbers
    Posted by Neil Kidney on May 17, 2013 at 9:09 am
    Hi guys,
    I have a 1.5 hour clip that I need to use in various edits using just a few seconds of the clip, and I have the start point for each edit as a frame number.
    Is there a way to set the in point numerically?
    Cheers.
    Kris Merkel replied 13 years, 4 months ago 2 Members · 1 Reply
  • Kris Merkel
    May 17, 2013 at 1:34 pm
    Open the clip in the Source window and double click on the Played timecode indicator. After the numbers are highlighted enter in your starting timecode and press enter. The playhead will move to that timecode position and you can then select your in point.
    “Think of everything in terms of building capacity.”
    Kris Merkel
    twitter: @kris_merkel
    Product Manager, Flanders Scientific Inc.
    http://www.shopfsi.com
    Co-Founder, Atlanta Cutters Post Production User Group
    http://www.atlantacutters.com
    2.2Ghz MBP core i7
    16Gb RAM
    CS6/FCP7
    AJA T-Tap
    AJA IO XT
    FSI LM-2461W/CM-170W
