Activity › Forums › Apple Final Cut Pro Legacy › Set all clips to (none) field
  • Set all clips to (none) field
    Posted by Aaron Neitz on February 12, 2008 at 7:40 pm
    FCP6 is driving me nuts. I need to adjust the Y axis on some PAL footage by 1 pixel here and there…. But as you know the only way to get crisp results is to have Sequence set to NONE fields and all your clips set to NONE fields.
    So I have about 120 clips that I need to set all of them to NONE. Any way? Paste attributes doesn’t seem to help. And I have 120 discreet master clips.
    Aaron Neitz replied 18 years, 7 months ago 2 Members · 3 Replies
  • Mark Rodway
    February 12, 2008 at 8:11 pm
    I had a similar problem from a FCP5 project – but had the clips in a timeline to change. I don’t know if this will apply to you in your bins (I expect it will) – but I selected a large number of clips (the most you can do at one time is 100 – why?). I then right clicked them and selected format. This brought them all up in a window and I went through manually changing them to None fields dominance…….
    As they are all in a line – it doesn’t take very long at all…..
    I hope that helps….. I can’t get in front of an edit system at the moment to check – but I think it’ll work.
    Mark
  • Mark Rodway
    February 12, 2008 at 8:23 pm
    Aaron,
    Doh………. I missed the simple answer. Select them all in your bin and right click the field dominance – change to None. All change to none. Job done.
    Mark
  • Aaron Neitz
    February 12, 2008 at 8:58 pm
    Ah HA! You’re a hero, that works
