Activity Forums Adobe After Effects Expressions set a function to call up a certain code based on a user dropdown choice
  • set a function to call up a certain code based on a user dropdown choice
    Posted by David Clabaugh on April 3, 2018 at 1:00 am
    HI,
    I am building a tool that will apply a set of effects to the selected layer. The effects parameters will change based on a drop-down UI element chosen by the user. What is the best way to implement the function? Currently, I am using an if/else if to call different settings to be applied to each layer, but that isn’t working.
    win=new Window("palette","FluentShadowUI",[0,0,200,100],{resizeable:true,independent:false,minimizeButton:false,maximizeButton:false,resizeable:false,});
    but_1=win.add("button",[20,60,120,80],"Fluent Shadow");
    but_1.helpTip="Select a layer";
    pixel_size=win.add("dropdownlist",[20,20,120,42] ,["1px","2px","3px","4px","6px","8px","9px","12px","16px","24px","32px","48px","64px","80px","96px",""]);
    pixel_size.helpTip="Choose your Shadow size";
    win.center();
    win.show();
    but_1.onClick = function(){
    if(pixel_size = "1px"){
    var effectsGroup = app.project.activeItem.selectedLayers[0];
    myEffect1px = effectsGroup.Effects.addProperty("ADBE Drop Shadow");
    effectsGroup.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0002").setValue(5.1);
    effectsGroup.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0003").setValue(180);
    effectsGroup.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0004").setValue(1);
    effectsGroup.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0005").setValue(4);
    effectsGroup.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0002").setValue(15.3);
    effectsGroup.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0003").setValue(180);
    effectsGroup.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0004").setValue(1);
    effectsGroup.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0005").setValue(4);
    effectsGroup.property("ADBE Effect Parade").property(3).property("ADBE Drop Shadow-0002").setValue(15.3);
    effectsGroup.property("ADBE Effect Parade").property(3).property("ADBE Drop Shadow-0003").setValue(180);
    effectsGroup.property("ADBE Effect Parade").property(3).property("ADBE Drop Shadow-0004").setValue(0.5);
    effectsGroup.property("ADBE Effect Parade").property(3).property("ADBE Drop Shadow-0005").setValue(4);
    }else if(pixel_size = "2px"){
    myEffect2px = effectsGroup.Effects.addProperty("ADBE Drop Shadow");
    myEffect2px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0002").setValue(5.1);
    myEffect2px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0003").setValue(180);
    myEffect2px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0004").setValue(2);
    myEffect2px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0005").setValue(6);
    myEffect2px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0002").setValue(15.3);
    myEffect2px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0003").setValue(180);
    myEffect2px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0004").setValue(2);
    myEffect2px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0005").setValue(6);
    }else if(pixel_size = "3px"){
    myEffect3px = effectsGroup.Effects.addProperty("ADBE Drop Shadow");
    myEffect3px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0002").setValue(5.1);
    myEffect3px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0003").setValue(180);
    myEffect3px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0004").setValue(2);
    myEffect3px.property("ADBE Effect Parade").property(1).property("ADBE Drop Shadow-0005").setValue(6);
    myEffect3px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0002").setValue(15.3);
    myEffect3px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0003").setValue(180);
    myEffect3px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0004").setValue(2);
    myEffect3px.property("ADBE Effect Parade").property(2).property("ADBE Drop Shadow-0005").setValue(6);
    James Ronan replied 8 years, 4 months ago 3 Members · 4 Replies
  • Andrei Popa
    April 3, 2018 at 8:33 am
    I don’t think that the if/else is the problem. You should call the selection by pixel_size.selection. However, when i have multiple choices, i usually use a switch statement. Easier to follow for me.
    Andrei
    My Envato portfolio.
  • David Clabaugh
    April 3, 2018 at 3:36 pm
    Thanks Andrei,
    I will swap in the .selection
    How would you put together a switch in this case?
  • David Clabaugh
    April 3, 2018 at 4:26 pm
    I have added the .selection parameter, but the function doesn’t execute.
    win=new Window("palette","The Fluent Shadow",undefined,{resizeable:true,independent:false,minimizeButton:false,maximizeButton:false,resizeable:false,});
    pixel_size.selection = 0;
    win.center();
    win.show();
    if(pixel_size.selection == "1px"){
  • James Ronan
    April 5, 2018 at 3:42 pm
    Try: pixel_size.selection.text === “1px”
    Like this:
    win.center();
    win.show();
    if(pixel_size.selection.text === "1px"){
    alert("1px");
    if(pixel_size.selection.text === "2px"){
    alert("2px");
    if(pixel_size.selection.text ==="3px"){
    alert("3px");
