Activity Forums VEGAS Pro Session File Corruption in Sony Vegas Pro 9.0 64bit
  • Session File Corruption in Sony Vegas Pro 9.0 64bit
    Posted by John Bires on February 4, 2010 at 6:39 pm
    Hey All,
    I have been using Vegas Pro 9.0c 64bit for the last 8 months or so without this issue, so I am wondering if maybe the group can shed some light on it. I am running a Quad Core system, Vista 64, 8gig RAM, Asus Commando Mobo, and using some WD 1TB drives connected to my Serial ATA on the mobo.
    I recently went back to open up some old projects that I had edited in November and December and when I looked on my drive, the session files had 0KB in their size. I had recently done a disk defrag on all my drives, but I hope that isn’t the issue. Sessions I had created previous to these projects and sessions created after these projects all seem to work fine. When I try an open them through the Vegas Open Dialog Window, I get descriptions in the bottom of the window that say “Unknown format” or “Stream attributes could not be determined”. Only one of the files that lists at 0kb actually has a Bak file associated with it, but without the source veg file I am not sure how to recover that bak file.
    Has anyone ever seen their session files turn into 0kb uknown files. Also the files are still maintaining the Icon flag as a Sony Vegas Project file.
    I have done the Ctrl-Shift Startup thing to clear out my caches and default the app.
    Just looking for some clarity here.
    -John
    Bob Peterson replied 16 years, 7 months ago 3 Members · 4 Replies
  • Daniel Nicholas
    February 4, 2010 at 7:45 pm
    I’ve just a similar problem after defragging last night I get up and open Vegas 9c and many of the audio sound effects I had in my latest project went from .wav audio to .sdk files and not even sure what that means except they have been corrupted. The only thing I have done since yesterday is the defrag. I would like to know more abou this because I put a lot of effort into getting the correct sound effects and not happy losing them.
  • Bob Peterson
    February 6, 2010 at 5:03 am
    Vegas creates .sdk files when it opens an audio file. It does nothing to the .wav file. So, your files have not been converted, but I have no idea where they are. I never run a defrag unless my system is backed up. That means I can recover if the defrag goes awry. What defrag program did you use?
  • Daniel Nicholas
    February 6, 2010 at 12:41 pm
    I used Defraggler program to defrag system. I just realized this posting says 64bit and I’m using 32bit Windows 7. Yes the only files that changed to .sdk were audio files but the originals disappeared. I got multiple prompts to relocate these when I reopened the project and a few I found (all in sound effects folder) and some were gone. Just vanished
  • Bob Peterson
    February 6, 2010 at 8:46 pm
    To repeat, Vegas does not “change” audio files to .sdks. It creates a second file, with the sdk extension, when it processes an audio file. It does not move, delete, or change the original audio file.
