Activity Forums Adobe Encore DVD serperating TS.bup from TS.ifo in the ECC block?
  • serperating TS.bup from TS.ifo in the ECC block?
    Posted by Deadittex on June 19, 2006 at 10:21 pm
    Okay so, it there a way to set it so that when I burn the disc, the video_ts.inf and bup are set to record to seperate places, is this in user settings or should I concern myself more with the actual burning program… zulu is what we use to burn the DVD’s we make them in encore.
    I guess they consider me the resident adobe expert around here because I can run AE and photoshop and audition(kinda) so now they just assume I know all the prooducts… which I should but sometimes it is like speaking manderan to some one who speacks cantonize, …
    Neil Wilkes replied 20 years, 1 month ago 2 Members · 1 Reply
  • Neil Wilkes
    August 5, 2006 at 2:19 pm
    Your buring software should do this automatically.
    If you are creating a folder from Encore, then avoid Nero as this is one of those that does not set the required gap between the 2 files.
    There may be others as well.
    If your burning software cannot handle this, then write from Encore as an image – or directly to DVD.
