Activity › Forums › Creative Community Conversations › Seriously though: New Mac or carry on with maxed out 5.1 Tower
  • Seriously though: New Mac or carry on with maxed out 5.1 Tower
    Posted by Terry Flaxton on April 24, 2020 at 4:05 pm
    So I ran with the 2012 5.1 tower I had rather than buying the new mac and I’m still wondering whether to cross over. The money is not an issue now (regardless of the pound dollar relationship which has us Brits paying through the nose) – the issue is whether or not it really does that much more – read below what a maxed out 5.1 does and tell me honestly how can I benefit (if you wouldn’t mind).
    So I have a 12 core with 128 ram, maxed it out with a 4 terrabyte OWC drive which would do (so they say) 6000 mbs read and write on a new mac but only makes about 1300 read and write on a 5.1 – I run Mojave from two different SSD one OWC accelsior one anglebird boot drives and Sierra from a 3rd old style if I need go back a generation for anything
    – but it appears I can do anything I want now: I always use about 6 layers of 4k (sometimes 10 layers before stuttering happens) – I find that although esata in and out was not supposed to work on Mojave – it still does – amazing! (I found this out after buying variations of cards to get a fast USB in – they always crashed the tower, the accelsior has two esata’s in but that don’t work and always was a problem). FCP is as stable as – and today for instance I’ve done around 100 point gash matte work for about 2 hours before it just crashes through boredom (I’m definitely bored and the crash snaps me out of zombie mode).
    So my big and very serious question now is: if I can do anything I want – why would I buy a new mac? One downside is waiting for a 4 min 4k with loads of layers and distortions and manipulations and colour grading on each layer and all the rest which will take about an hour to transcode and an hour to upload to Vimeo ( we have about 70 mbs in the sticks in the UK but it’s the transcode that’s taking the time)… SO: Will the new mac (and what number of cores and set up) make this move necessary? and I mean by necessary a lot faster – Or is it the same old same old and only a marginal increase of computing power when it really comes down to it (because in reality they’ve concentrated on the plumbing in to apparently speed the kit up). So I’m also asking with regard Motion – or Maya come to that as I realise I need make more 3D stuff.
    Made my first video in 1976, A long term programme maker, DP, editing etc – changing with AR/VR/MR media –
    Terry Flaxton replied 6 years, 3 months ago 9 Members · 19 Replies
  • 19 Replies
  • Oliver Peters
    April 24, 2020 at 4:43 pm
    You are probably still getting enough performance to hang in there a while longer. It’s hard for anyone to say you will or won’t get significantly faster results without exactly duplicating your file format and workflow. A new machine – iMac Pro or Mac Pro – will likely be faster/better, but does the cost offset the performance gains? Unknown.
    You may get better transcode speeds, if – 1 )you use background transcode, and/or 2) export to ProRes first. If you use background transcode, that optimized media will be used in your export, so the export is faster. If you export to ProRes and then transcode that flat ProRes master file for Vimeo, the total time may be faster than a direct export to Vimeo specs.
    – Oliver
    Oliver Peters – oliverpeters.com
  • Patrick Sheppard
    April 24, 2020 at 6:10 pm
    Terry,
    To your note about the OWC drive — which I assume is the Accelsior 4M2 based on the 6,000 MB/s spec — there may be a few things going on there that are affecting the read/write speed.
    First, your Mac Pro model uses PCIe 2.0, which is about half the speed of PCIe 3.0. The 4M2 is PCIe 3.0 and therefore achieves the advertised 6,000 MB/s speeds with PCIe 3.0, even though it is backwards compatible with PCIe 2.0.
    Second, the 4M2 is an x8 (aka 8-lane) card, so even if you have it installed into one of your bottom two PCIe slots, which are x16 (aka 16-lane), you would only see a theoretical maximum speed of 4,000 MB/s (and in reality it would be less than that due to system overhead).
    But based on your stated read/write speeds, it sounds like maybe you have the 4M2 installed into one of the top two PCIe slots? If so, that would explain the 1,300 MB/s speeds you reported. The top two PCIe slots are x4 (aka 4-lane), for which the theoretical top speed is 2,000 MB/s, and in reality is more like 1,500 MB/s — which is very close to the 1,300 MB/s that you’re seeing.
    To sum up, it sounds like what’s happening is that the 4M2 card is being speed-crippled three times over:
    — first, by the speed difference between PCIe 2.0 and 3.0;
    — second, by the fact that the 4M2 card is only x8 and therefore would only get up to x8 speeds even when installed into one of the Mac Pro’s x16 slots; and
    — third, if I’m right about the 4M2 actually being installed into one of the top two PCIe slots, then you’d only have an effective speed consistent with PCIe 2.0 x4.
    If the third factor is true, then you should see a significant speed increase by moving the 4M2 card to one of the Mac Pro’s bottom two PCIe slots. Or if it is already installed into one of those slots, then there’s something else affecting the read/write speed.
  • Terry Flaxton
    April 24, 2020 at 9:10 pm
    Hey thanks – you are right about the top two slots – it’s 22.00 at night here in the UK but will try this tomorrow morning and report back. There’s a graphics card in the bottom slot.
  • Bernard Newnham
    April 25, 2020 at 8:43 am
    Given that Apple look like they are going to dump Intel – I read in The Times – it’s probably a bad time to think of updating. What if they decide to EOL the incredibly expensive new MacPro you just bought and tell you that the even newer MacARM is the only thing to buy? It comes with wonderful new Thunderbolt and Lightning MegaPower (TM) and brand new SuperConnectors (TM), so you’ll be the proud owner of the very fastest and amazingness computer anywhere. And the biggest willie. But you won’t be able to use any of the peripheral gear that cost you a fortune not too long ago.
    Bernie
  • Terry Flaxton
    April 25, 2020 at 8:51 am
    Yes I did see the news report and immediately worried about arm chips and how they just might not work with older software that would get modified and lead us down the same apple maze that’s been going on for years. It makes me wonder – because we all might think of Steve Jobs as being the golden era (albeit broken up into different parts and histories what with the head of windows getting hold of it and signing away core ideas), but he was interested in instability too. These days however the costs are huge – but and this always comes right back at you, the other routes are equally unpalatable…
  • Terry Flaxton
    April 25, 2020 at 9:38 am
    Patrick – I knew there was a reason that I didn’t put the $M2 in the second to bottom slot: The Saphire RX580 graphics card is big and when you add the 4M2 just above it which has two little elements hanging down into the path of the fan blades….
    So the only other possibility is a new graphics card with a lower profile – $$ (and I chucked out an nvideo Quadro K2000 for the 580)….
    And I hear that the Expansion slot Utility that went is now coming back with the new macs and catalina – I wonder if I should go from Mojave to Catalina just to get that to move slots around with expansion slot utility? But then I have a tempo esata card that still works on Mojave (when I beleive it shouldn’t) will Catalina kill that operability???
  • Steve Connor
    April 25, 2020 at 11:10 am
    [Bernard Newnham] “What if they decide to EOL the incredibly expensive new MacPro you just bought and tell you that the even newer MacARM is the only thing to buy? It comes with wonderful new Thunderbolt and Lightning MegaPower (TM) and brand new SuperConnectors (TM), so you’ll be the proud owner of the very fastest and amazingness computer anywhere. And the biggest willie. But you won’t be able to use any of the peripheral gear that cost you a fortune not too long ago.”
    Not going to happen
  • Herb Sevush
    April 25, 2020 at 1:26 pm
    Reasons to upgrade:
    Thunderbolt 3, which makes a huge difference when dealing with external raids and drives.
    GFX card upgrades, blowing away the performance of the 580.
    Catalina compatibility (and all future OSX upgrades)
    Are these enough to justify the cost? YMMV.
    Herb Sevush
    Zebra Productions
    nothin\’ attached to nothin\’
    \”Deciding the spine is the process of editing\” F. Bieberkopf
  • Oliver Peters
    April 25, 2020 at 2:15 pm
    I think we have to take the ARM stories with a grain of salt. While it may make sense for a replacement for the basic MacBook, these chips aren’t up to the task of the heavy lifting handled by Apple’s current crop of Core i7, i9, and Xeon CPU. Maybe in a few years, but not around the corner. So does it make sense to run a bifurcated approach with macOS?
    – Oliver
  • Terry Flaxton
    April 25, 2020 at 2:35 pm
    Patrick – I tried again and put the 4MT2 above the Saphire 580 and blocked it up enough to clear the blades, put the tempo esata back (which shouldn’t work in Mojave according to both Sonnet and apple) but does and it all now works – I’ll check it for over heating.
    Thanks you again, I’ve just got an extra 1000mbs and can watch what I’m doing in 4k in best quality in best performance! Fantastic.
