Activity Forums Apple Final Cut Pro Legacy seriously beginning to panic!
  • seriously beginning to panic!
    Posted by Jessica Shaughnessy on July 15, 2008 at 7:50 pm
    I really hope somebody can help me….
    I have been filming on my Canon XHA1 in SD 16:9 PAL (I went down from HDV because of the codec problems with QT7).
    It captured and edited in FC6 fine, absolutely no problem, all looked nice in widescreen. But when I export it, it changes to 4:3. I have solved this initially by dragging it into QT and exporting it from there as widescreen.
    Only problem is, when I bring it into sorenson squeeze or any other software to convert it to a wmv or flv it goes back to 4:3 again. Even when i import the quicktime file back into FC it does the same thing. I have tried altering the sequence settings but i just get the same when i export it.
    Any ideas? I need to solve this problem by the end of the week so any advice would be greatly appreciated. thanks in advance….!!!!
    Jessica Shaughnessy replied 18 years, 1 month ago 4 Members · 7 Replies
  • 7 Replies
  • Jeremy Garchow
    July 15, 2008 at 8:14 pm
    16×9 Sd material is known as anamorphic. Anamorphic is 16×9 material squeezed in to a 4×3 window as SD is only 4×3.
    Read this and write back with questions:
    https://forums.creativecow.net/thread/8/993015
    Ignore the stuff about the sound.
    Jeremy
  • Aaron Neitz
    July 15, 2008 at 8:16 pm
    no panic, simple explanation:
    when you’re in SD, there’s often a way of working in 16×9 that’s called anamorphic. SD can’t be anything but 4:3, so to squeeze all that horizontal resolution out they simply squish your image into that 4:3 box. The computer or TV needs to know that it’s squished (anamorphic) and automatically stretches it out to a letterbox presentation.
    So in Sorenson you need to tell it that this needs to be unsquished and played as 16×9. Instead of 320×240, you’ll end up with 320×180 (or something to that effect.) Also when brining footage like this into FCP, there’s a box called “anamorphic” in your bins that you need to check. Then FCP will know what to do!
    hope this helps!
  • Jessica Shaughnessy
    July 15, 2008 at 8:29 pm
    Thanks for replying so quickly,
    the problem on the other thread seems to be the other way round to mine, but I do understand it a little better.
    from capture to export, i checked every anamorphic option – or so I thought. do you think i am having this problem because i might have missed one out?
    maybe if i export as hd 16:9, the aspect ratio would stick?
    thanks again
    July 15, 2008 at 8:40 pm
    thank you, sounds very basic when you explain it like that!
    only problem is, there doesnt seem to be a way of marking it anamorphic in sorenson!? I don’t suppose you know how?
    Thanks again (i am pretty new to all this)
  • Jeremy Garchow
    July 15, 2008 at 10:18 pm
    Your footage is anamorphic, no? Or is it already letterboxed? If it’s 16×9 squeezed in to a 4×3 aspect, then it is just the same as the other thread.
    You need to put a 16×9 pixel count in sorenson and it will stretch your footage approproately.
    16×9 pixel counts are 640×360, or 480×270 or 320×180. You need to modify your settings to match those (they have a constrain aspect ratio option to help you as well).
    Jeremy
  • Tom Brooks
    July 15, 2008 at 10:43 pm
    Sorry I don’t have Squeeze in front of me at the moment, but I believe there’s a place to set aspect ratio at the top of the main window. It defaults to 4:3, but you can set it to 16:9 up there. I think this is the only place you specify your source as anamorphic. As others said, your output will be 16:9 with square pixels, such as 640×360 or 320×180.
    July 15, 2008 at 11:39 pm
    Cracked it. thanks everyone for your help!
    Jess
