Activity Forums Maxon Cinema 4D Seriously Apple… AppNap?
  • Seriously Apple… AppNap?
    Posted by Quintus Lubbe on March 13, 2014 at 2:51 am
    I was hugely frustrated doing a recent project. I would animate during the day and render at night, but in the morning would find that Cinema 4D had only rendered out a few frames. With the deadline looming and after having searched online, I found out that Mavericks has a new “function” that it has added to apps called AppNap. It basically puts apps into idle mode when it thinks they’re not being used. Frame renders would go from 1 minute each to around 10 minutes with AppNap on. To switch off go to application icon > GET INFO > uncheck AppNap then restart the application.
    Hopefully this helps someone having the same problem.
    I seriously would’ve thought that Apple would have made this more known in the update info.
    Quintus Lubbe replied 12 years, 6 months ago 2 Members · 2 Replies
  • Brian Jones
    March 13, 2014 at 2:57 am
    Thanks. Good info for those who had not heard but just to be accurate it’s check Prevent AppNap
  • Quintus Lubbe
    March 13, 2014 at 2:59 am
    Sorry, quite correct, I’ve been up through the night so not thinking clearly!
