Activity Forums Apple Final Cut Pro Legacy Serious Trouble with reverse telecine 16mm – field 2 only – Please help!!!
  • Serious Trouble with reverse telecine 16mm – field 2 only – Please help!!!
    Posted by Daniel Fiori on June 27, 2008 at 3:36 am
    I´m working for the first time in Brazilian Cinema as a assistent editor and i`m having a serious problem with Cinema Tools Reverse Telecine.
    I´ve read the manual but I can´t get any solution.
    We shoot the movie in 16mm with an Aaton minima camera.
    The telecine was made to dv tapes.
    I´ve created a database in Cinema tools with the flex files, exported a xml to final cut and batch captured.
    My problem is:
    When I use the Cinema tools reverse telecine and open my clip in Final Cut (6.0.3), it still contain fields and I can´t read the letters of the window burn
    The field pattern is A2 B2 C1 D1 D3 — Field 2 only as we can read in the manual.
    I´m reversing for 23.98 fps
    I´ve tried with the “Standard upper/lower” checked and unchecked with no positive results… When I open in the Final Cut, in a 23.98 project, and see the clip
    frame by frame, I can´t read the letters and there is fields…
    In page 132 of Cinema tools manual,you can read in the “Check telecine results” session —> “each letter should be clearly legible…”
    That´s my nightmare… What should I do? Can anyone give me a solution for this problem??
    Thanks for reading…
    Sean Oneil replied 18 years, 2 months ago 2 Members · 3 Replies
  • Sean Oneil
    June 27, 2008 at 8:26 am
    Have you tried all five cadence options?
    Sean
  • Daniel Fiori
    June 27, 2008 at 11:48 pm
    Yes, i´ve tried all the options… And… the pulldown is still there…
  • Sean Oneil
    June 28, 2008 at 1:24 am
    Are you sure the source contains 3:2:3:2 pulldown? As you jog through it you should see three full progressive frames followed by two frames that have mismatched fields. And then it will repeat.
    Sean
