Activity Forums VEGAS Pro Serious rendering issue
  • Serious rendering issue
    Posted by Tannie Low on July 12, 2012 at 7:05 pm
    Plays back in VLC and QuickTime like this: https://secularuh.org/problem.png
    Settings like this: https://secularuh.org/render.png
    General
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    Overall bit rate : 10.5 Mbps
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Baseline@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 3s 203ms
    Bit rate mode : Variable
    Bit rate : 10.3 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Standard : NTSC
    Color space : YUV
    Mikhail Petrushin replied 14 years, 2 months ago 2 Members · 2 Replies
  • Tannie Low
    July 13, 2012 at 2:16 am
    I was able to successfully render the videos; first in Vegas as a WMV, then through Adobe Media Encoder to MP4 to get the 1:1 aspect ratio for Vimeo.
    I’d love to understand what was going on. And understand codecs more appropriately as well, specifically how to manage them.
    I made a list with InstalledCodec, anything look wrong with this?
    https://secularuh.org/hosted/InstalledCodec_2012_07_12.htm
  • Mikhail Petrushin
    July 13, 2012 at 11:45 am
    It looks strange that you choose “Main” profile in codec’s settings, however in media info it shows “Baseline”. Also, bitrate in media info is higher than in the codec’s settings. Are you sure that this media is rendered with these codec’s settings?
    You can try to disable GPU usage by set “Encode Mode” to “Render Using CPU Only”.
    Also, don’t forget to set “Video Render Option” to “Best” on the Project Tab.
    P.S. I don’t know if it helps in your players because I don’t use VLC and QuickTime.
