Activity Forums Blackmagic Design Serious problems installing decklink driver and presets to Adobe production studio
  • Serious problems installing decklink driver and presets to Adobe production studio
    Posted by Bogeyb on May 16, 2006 at 4:19 pm
    Hello,
    I tried to install the 5.42 and the 5.5.1 driver with no luck. There are no presets and plugins in the Adobe Premiere Pro 2.0 Folder installed.
    The Install-log file shows that the installer tried to copy the files to drive ‘D:’ but the production studio is installed on drive ‘L:’
    So I searched the forum and found a solution to copy the .prm files and the presets manually to the apropriate folders. Now I can see the Presets, but when I try to start a new Project with one of the decklinks’ presets, Premiere Pro 2.0 crashes with “a serious error has occured”-message.
    Has anyone an idea how to solve my problem??? Did I forget to copy some files???
    Here is some text from the install-lof file:
    DeckLink Install – installing drivers…
    DeckLink Install – installing Adobe Premiere Pro plugins and presets…
    CAdobePremiere::Install() – install path is ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\’
    CAdobePremiere::FindPremiereDirectories() – version 1.5 ERROR ZERO length plugin path!
    CAdobePremiere::FindPremiereDirectories() – version 2.0 plug-in path is ‘D:\Programme\Adobe\Premiere Pro 1.5\Plug-ins\de_DE’
    CAdobePremiere::CopyPremiereFiles() – version 2.0
    src path is ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\Premiere Support’
    dst path is ‘D:\Programme\Adobe\Premiere Pro 1.5\Plug-ins\de_DE’
    CAdobePremiere::CopyPremiereFiles() – version 2.0, ERROR with directory ‘D:\Programme\Adobe\Premiere Pro 1.5\Plug-ins\de_DE’
    CAdobePremiere::DeleteFiles() – version 2.0
    delete path is ‘D:\Programme\Adobe\Premiere Pro 1.5\Settings\de_DE\Blackmagic Design’
    CAdobePremiere::CopyPremierePresetFiles() –
    src path is ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\Premiere Support\2.0’
    dst path is ‘D:\Programme\Adobe\Premiere Pro 1.5\Settings\de_DE\Blackmagic Design’
    CAdobePremiere::CopyPremierePresetFiles() – processing ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\Premiere Support\2.0\HD720=10 bit YUV=50p.prpreset’
    CAdobePremiere::CopyPremierePresetFile() – ERROR with directory ‘D:\Programme\Adobe\Premiere Pro 1.5\Settings\de_DE\Blackmagic Design’
    CAdobePremiere::CopyPremierePresetFiles() – processing ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\Premiere Support\2.0\HD720=8 bit YUV=24p.prpreset’
    CAdobePremiere::Install() – Completed.
    DeckLink Install – setting Adobe After Effects preferences…
    DeckLink Install – installing Adobe Photoshop plugin…
    CAdobePhotoshop::Install() – install path is ‘C:\Programme\Blackmagic Design\Blackmagic DeckLink\’
    CAdobePhotoshop::InstallerOperation() – Located subkey ‘Software\Adobe\Photoshop\9.0’
    CAdobePhotoshop::InstallerOperation() – Located plugin path key ‘Software\Adobe\Photoshop\9.0\PluginPath’
    CAdobePhotoshop::InstallerOperation() – GetFileAttributesEx() FAILED for ‘L:\Adobe\Adobe Photoshop CS2\Plug-Ins\’ err 2 index 0
    CAdobePhotoshop::Install() – Completed.
    DeckLink Install – installing QuickTime codec…
    DeckLink Install – installing control panel…
    DeckLink Install – Adding registry entries …
    DeckLink Install – completed 0x00000000.
    Bogeyb replied 20 years, 4 months ago 2 Members · 2 Replies
  • Andrew Mcleod
    May 17, 2006 at 4:15 am
    Hi
    Is it possible you changed drive mappings after the installation of production studio ?
    Recommend starting the installation of production studio again to avoid any manual copying of files.
    Ensure you have DirectX9.0, Quicktime7.0, SP2 before installing production studio – then once you are set up – install the Decklink driver last.
    Presets should then be available in all supported applications.
    Any problems email – pcsupport@blackmagic-design.com
    Andrew McLeod
    Blackmagic Design
  • Bogeyb
    May 19, 2006 at 9:07 am
    I reinstalled Premiere Pro. Same error messages in the installation log file, BUT: everything works fine now!!!
    I don’t know why but I don’t mind
    Thanks for your help,
    Sebastian
