Activity › Forums › Apple Final Cut Pro Legacy › Serious long export Times, is this normal?
Posted by Josh Evans on October 14, 2008 at 7:29 pmIm on a Macbook PRo 2.4ghz, exporting a 90 minute Mpeg2 from compressor to be made into a DVD. Seems to be taking around 15 hours. Is that normal?
Kevin Monahan replied 17 years, 10 months ago 3 Members · 4 Replies -
Shane Ross
October 14, 2008 at 8:06 pmWhat format are you compressing? HDV? DV?
Shane
Read my blog, Little Frog in High Def -
Kevin Monahan
October 14, 2008 at 8:53 pmIndicates something may be wrong with your media drive. Give us the low down on it and the last time you repaired it.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro -
Josh Evans
October 15, 2008 at 7:47 amIts a Lacie Firewire 800, 750 Gig.
I bought it new just a couple of months ago, had no problems with it so far. Is this a drive issue, or some sort of bug in FCP do you think?
Never had this problem before, Im assuming its something to do with the long timline, since until now i never cut anything longer than 22 minutes. This is 3 hours.
Kevin Monahan
October 15, 2008 at 11:14 pmNew drive? Definitely a culprit. How’s it formatted? HFS + ? Journaled or not?
Kevin Monahan
