Activity › Forums › Adobe Premiere Pro › Serious issue related to activation/deactivation and reinstall
  • Serious issue related to activation/deactivation and reinstall
    Posted by Steve Brame on April 22, 2013 at 3:19 pm
    Got a serious issue going one. I had deactivated my Premiere Pro CS6 install on my main system while I was traveling and activated the install on my laptop. When I returned, I deactivated the laptop and re-activated the main system again. Any AVCHD clips that were already there were recognized, but if I tried importing any new ones, I’d get the “Unsupported compression type” error. Realizing that this is usually an activation issue, I tried to deactivate so that I could reactivate, but the Deactivate selection was grayed out. So, I uninstalled and ran the clean up tool. Then re-installed from the Cloud and activated. I could then import new AVCHD media without the “Unsupported compression type” error, however, now the project I was working on opens, but nothing will play – neither in the Timeline or the Source Monitor. Hitting “Play” does nothing. I can move the CTI along the Timeline but the initial frame that is in the Program Monitor stays the same. Furthermore, when I try to Save, the program hangs, forcing me to end Premiere from the Task Manager.
    Here’s what I’ve tried as possible remedies…
    – Created an empty project and imported the working project into it – same thing happens in the new project
    – Created an empty project and imported individual sequences from the bad one. This works, however, one of the sequences in the bad version doesn’t appear in the list of sequences when importing, providing a clue as to where the problem lies.
    – Trashed preferences
    – Cleaned Media Cache Database
    – Deleted all Previews
    I’m at an impasse. Any suggestions would be greatly appreciated.
    “98% of all computer issues can be solved by simply pressing ‘F1’.”
    Steve Brame
    creative illusions Productions
    Steve Brame replied 13 years, 5 months ago 2 Members · 5 Replies
