Activity › Forums › Apple Final Cut Pro Legacy › Serious help needed please
  • Serious help needed please
    Posted by Mindcrime on June 7, 2006 at 3:18 pm
    I just completed a DVD project,just prior to a major melt down of my harddrive causing me to lose everything, But the bright spot is I have the final DVD done, the problem is, I need to insert a song/video into the project, now the only way I see that I can do this is to rip the dvd cut it up insert the missing song and reasemble, the problem is when I re-render the files I lose quality, can anyone give me a quick answer to this, please,
    System: Mac G5
    4gigs Ram
    final cut pro 5.0.1
    John Fishback
    replied 20 years, 3 months ago
    5 Members · 4 Replies
  • No other way except to rip the DVD files, or capture the DVD from a player as an analog source.
    Better by far would be to recreate your project using a new hard drive.
    If you “can’t”, your’re going to have to live with the DVD source.
  • Captain Mench
    June 7, 2006 at 5:36 pm
    You MIGHT want to try ripping it as an mpeg2 and audio file… this might save the quality. Then rebuild it in DVDSP by adding a story marker pointing to the song you need to insert.
    CaptM
  • Kevin Monahan
    June 7, 2006 at 7:03 pm
    Why not recapture from your original project file. Don’t tell me that the only version lived on the fried HD! 😉 If so, another reason to back up project files to iDisk or the like.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
  • John Fishback
    June 7, 2006 at 9:34 pm
    MPEG Streamclip is a free app that will help you do what you need. I used it recently when the only source was a DVD of a corporate project. I used the 8-bit uncompressed codec and was amazed at the quality. I got much more that I expected. https://www.squared5.com/svideo/mpeg-streamclip-mac.html
    John
    Dual 2.5 G5 4 gigs RAM OS 10.4.3 QT7.0.3
    Dual Cinema 23 Radeon 9800
    FCP Studio 5 (FCP5.0.4, DVDSP4.0.2, Comp2.0.1, STP1.0.2)
    Huge U-320R 1TB Raid 3 firmware ENG15.BIN
    ATTO UL4D driver 3.50
    AJA IO driver 2.1 firmware v23-28
    SonicStudio HD DAW, Yamaha DM1000, Genelec Monitors
