Activity Forums Adobe Premiere Pro Serious error on CS3 and shut down
  • Serious error on CS3 and shut down
    Posted by Brandan Baki on February 14, 2008 at 7:02 pm
    While using Premiere Pro CS3 I often recieve a message that states, “Sorry, a serious error has occurred that requires Adobe Premiere Pro to shut down. We will attempt to save your current project.”
    This ONLY happens when I have a bin open. I am using it like a storyboard. And I can “automate to sequence” no problem. BUT when I change the speed on clips the message comes up and the program closes. I can change the speed of one clip and its fine. But more than that, it closes.
    I have only been using the program for a few weeks. I was changing speed and sutomating for a while and then this started and won’t stop. I have tried everything I can think of. I can change the speed within the sequence, which is how I am getting by. But I am really curious why this happens.
    I have created new projects and tried new clips. I have leveled it down to only happening when I change the speed. Nothing else.
    Ray Abiva replied 17 years, 6 months ago 3 Members · 4 Replies
  • Darren Edwards
    February 15, 2008 at 9:39 am
    Have you installed the 3.1.1 update yet?
    That’s said to fix a few critical bugs.
    D.
    x-gf.com
  • Brandan Baki
    February 15, 2008 at 5:53 pm
    Yes. I have installed 3.1.1.
    That is all though. Perhaps there are more updates? I have checked but not found any.
  • Darren Edwards
    February 15, 2008 at 6:35 pm
    Sounds like you might need the help of the beta
    testers and experts over at Adobe’s forums.
    (I’d help you but I haven’t the ‘privilege’ of
    installing the full CS3 suite yet. I have it here,
    ready, just not the time to put our machines out
    of action for a few days whilst it installs.)
    https://www.adobeforums.com/cgi-bin/webx/.3bbe4d6a/
    Good luck,
    Darren.
    x-gf.com
  • Ray Abiva
    February 14, 2009 at 2:14 am
    We have the same scenario and its really not good. I’m digging throughout the net to find solution but unfortunately I haven’t find anything yet though I’ve tried a few things. I will back here if I find the solution.
    Yes! You can do it by yourself!!
    https://www.ehows.blogspot.com
