Activity Forums Apple Final Cut Pro Legacy Serious Capture Problem
  • Serious Capture Problem
    Posted by Zeliha Bozkurt on June 29, 2006 at 3:24 pm
    Hi
    I am using FCP version5.0.2 and digitizing a Beta SP from Sony J30 into Final Cut.
    The problem is the clips I digitize doen’t carry the timecode from the tape instead all my clips starting timecode is 00.00.00.00 after digitizing.
    Please Heeeeeeeeeelp!
    Zee.
    Walter Biscardi replied 20 years, 2 months ago 3 Members · 2 Replies
  • Steven Gonzales
    June 29, 2006 at 4:03 pm
    Are you using serial control with the deck? This is how the timecode would be communicated between the tape and Final Cut Pro.
  • Walter Biscardi
    June 29, 2006 at 5:55 pm
    I run a J3/902 here with RS-422 and it works fine. Be sure you’re set up for RS-422 control
    Walter Biscardi, Jr.
