Activity Forums Apple Final Cut Pro Legacy Serialization error (Exporting as MPEG2 files)
  • Serialization error (Exporting as MPEG2 files)
    Posted by Riccardo Zito on August 17, 2005 at 1:52 pm
    Hello all,
    I have been trying to export MPEG2. I have the upgraded version of qucktime 7. I also have DVD Studio pro.
    When I try export I get the following error message: “Serialization error- DVD Studio Pro must be serialized first in order to run Quicktime MPEG Encoder.”
    Suggestions anyone?
    I greet you thankfully.
    Riccardo
    hotmale
    Joe Langenfeld replied 21 years ago 6 Members · 11 Replies
  • 11 Replies
  • Walter Biscardi
    August 17, 2005 at 1:53 pm
    sounds like you haven’t entered your serial number for DVDSP yet. Launch DVDSP and enter the serial number.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
    Now editing “Good Eats” in HD for the Food Network
  • Riccardo Zito
    August 17, 2005 at 1:58 pm
    Actually I have entered the SN. Both of them !
    No go.
    Thanks Walter.. keep the suggestions coming if you have any more
    r.
    hotmale
  • Arnie Schlissel
    August 17, 2005 at 5:07 pm
    [riccardo zito] “Actually I have entered the SN. Both of them !”
    Both? There should be only 1 SN for DVDSP. Are you sure that you’ve entered the correct one?
    Arnie
    https://www.arniepix.com
  • Riccardo Zito
    August 17, 2005 at 5:27 pm
    well I get two serial number prompts.. and I have two serial nubers. It is DVD Studio Pro 2..
    we are talking about the same thing right?
    hotmale
  • Arnie Schlissel
    August 17, 2005 at 5:34 pm
    [riccardo zito] “we are talking about the same thing right?”
    Apparently not.
    DVDSP has only 1 SN, and when you do an install, you’re only prompted once. What’s the 2nd SN for? QT? FCP?
    Arnie
  • Michaelle Stikich
    August 17, 2005 at 5:46 pm
    Sadly, when you upgrade to QT 7, you lose the ability to export MPEG 2 files via QT. They expect you to use DSP or Compressor. I think that error is some weird way of tell you to use compressor instead. but maybe I’m wrong?
    gir
  • Riccardo Zito
    August 17, 2005 at 5:47 pm
    The interface is still that of DVDSP.. no mention of any other software QT or anything else.
    I am confused. If I open DVDSP it runs just fine.
    hotmale
  • Aaron Neitz
    August 17, 2005 at 6:47 pm
    This is what happened to me. Until now no one has responded to my questions about “where did export to MPEG-2 go?” thanks for confirming this.
  • Riccardo Zito
    August 17, 2005 at 6:56 pm
    Actually I do have the option to export to MPEG 2 from Final Cut.
    It just doesnt do it though.
    Once I downloaded Quick time 7 (the high quality version i.e. not the free one) It automatically appeared into the export format option of ” File>export>using quick time conversion…”
    So in theory you just need to get a quick time version that has the MPEG 2 encoder.. in Theory.. thats where I get stuck though. I get wierd messages about DVD Studio Pro..
    hotmale
  • Arnie Schlissel
    August 17, 2005 at 7:05 pm
    [riccardo zito] “Once I downloaded Quick time 7”
    OK, I missed that part of your 1st post. I don’t think you can use that workflow with QT7 & DVDSP2. My guess is that DVDSP is looking for QT6. Try encoding your m2v files with Compressor, instead.
    Arnie
