Activity Forums Apple Final Cut Pro Legacy serial numbers
  • Posted by Craig Mcgillivray on February 3, 2010 at 12:33 am
    Things have gotten confused in my little studio. The idiot in charge of reinstalling FCP on two machines(let’s call him me), tried to save a little time and cloned the OS and FCP to machine A, FCS3 upgrade from FCS2. Normally Machine A has the FCS3 install on it. I entered the serial number that’s taped on the case and all is fine. Then I went to machine B and figured I’d save some time over installing FCS2, then the Upgrade, and just do the FCS3 install. I got a dialog box saying that the serial I’m using is an upgrade serial and I can’t do that. So, in an after lunch food coma I went ahead with that install-forgetting that I can’t run two machines on a network with the same serial number. So, if anyone is still with me at this point, is there a way for me to straighten out my conflicting serial numbers-basically I need to change the serial number on machine A to the upgrade serial number. Or am I reinstalling? thoughts.
    Lea Mclean replied 15 years, 11 months ago 3 Members · 4 Replies
  • Michael Sacci
    February 3, 2010 at 1:31 am
    “system drive”/Library/Application Support/ProApps/Final Cut Studio System ID
    Move that file to the trash (don’t empty it until you complete the process)
    Lauch FCP and it will ask you for the Ser# again.
    BTW, you don’t not (nor should you) have to install the version you are upgrading from. If FCS2 is not installed all you need to do is enter the old ser #. you do not install FCS2 before you install FCS3 upgrade.
  • Craig Mcgillivray
    February 3, 2010 at 1:48 am
    thank you sir. You just saved me hours of time eating bowls of crow.
    -c
  • Michael Sacci
    February 3, 2010 at 1:58 am
    no problem, been there, so I know the pain.
  • Lea Mclean
    October 19, 2010 at 10:36 pm
    Hi there, I’m having the same issue. I have trashed the Final Cut Pro System ID, as per the instructions you have given but FCP still launches as normal. I then emptied the trash and FCP still launches as normal with the previous serial number. Any other ideas would be of great help.
    L
