Activity Forums Zaxwerks Serge Filmstrip (other question)
  • Serge Filmstrip (other question)
    Posted by Julio Crespo on August 27, 2006 at 1:24 am
    I finish your tut and have an idea for that method, but a can do the ilustrator paht render correctly on invig, maybe this is no the right forum… but how do you made only one ilustrator path render on ivig? couse i try to make a resistor shape and the render seems like a plate. Sorry if I dont explain well.
    thanks in advance
    Jon Okerstrom replied 20 years, 1 month ago 2 Members · 1 Reply
  • Jon Okerstrom
    August 27, 2006 at 2:29 am
    Hi PRgraphist.
    You can make a resistsor shape by using two Illustrator circles. One representing the diameter of the resistor and a smaller one representing the wire that passes through it. You the adjust the z depth of each object and change the bevel to something small. That should do it.
    Does this help?
    Jon
