Activity Forums Adobe After Effects Expressions Sequential function execution for sourceText property
  • Sequential function execution for sourceText property
    Posted by Cricket Collins on July 8, 2025 at 8:18 pm
    Hi, all.
    I’ve been poking at this one for a while now and would like some help. I’m trying to combine two fairly complicated expressions to connect the sourceText property of a text layer to define and link to a dropdown menu in a control layer for font selection and to a slider on the same layer to allow a limited amount of characters per line (the latter of which I found on here, from Dan Ebberts). I’ve tried a few methods, but here’s where I’m at now:
    font01 = "ProximaNova-Black";
    font02 = "ProximaNovaCond-Black";
    font03 = "ProximaNovaExCn-Black";
    font04 = "ProximaNovaExWd-Black";
    font05 = "ProximaNovaWide-Black";
    font06 = "ProximaSera-Black";
    font07 = "ProximaSoft-Black";
    font08 = "ProximaSoftCond-Black";
    font09 = "ProximaSoftExCn-Black";
    dropMenu = comp("Master").layer("Control").effect("Dropdown Menu Control")("Menu").value-1;
    const fontArray = [font01, font02, font03, font04, font05, font06, font07, font08, font09];
    const iterator = fontArray[dropMenu];
    txt = text.sourceText;
    n = comp("Master").layer("Control").effect("Text Width")("Slider");
    outStr = "";
    newLine = "";
    splt = txt.split(" ");
    function txtp() {
        for (i = 0; i < splt.length; i++) {
            if ((newLine + " " + splt[i]).length > n) {
                if (outStr != "") outStr += "\r";
                outStr += newLine;
                newLine = splt[i];
            }else{
                if (newLine != "") newLine += " ";
                newLine += splt[i];
    if (newLine != "") {
        outStr += newLine;
    outStr;
    text.sourceText.style
        .setFont(iterator)
        .setText(txtp)
    The font selection is working great, but I’m stumbling in two places here:
    • First, for some reason the .setText(txtp) is filling the whole function into the source text, including the word “function” at the beginning all the way through the last }. It’s not executing txtp(), just changing the source text to “function textp() {” etc.
    • Second, I’m aware part of the problem is that the txtp() function doesn’t return a value compatible with the .setText operator, but I’m not sure how to fix this. If I could get it to somehow return the modified text, that would be great.
    Brie Clayton replied 1 year, 1 month ago 3 Members · 5 Replies
  • Dan Ebberts
    July 8, 2025 at 9:22 pm
    Try changing the last line to:
    .setText(txtp())
  • Cricket Collins
    July 8, 2025 at 9:52 pm
    That took the function out of the source text, but wiped the source text itself so now the layer is blank…
    Before & after screenshots attached.
    This is also what happens when I change
    [code]
    .setFont(iterator)
    .setText(txtp())
    to
    txtp()
    in order to only run the function and nothing else, which is what makes me think the function itself may not be returning text. Not sure why, though.
  • Dan Ebberts
    July 8, 2025 at 10:06 pm
    Sorry, I didn’t test it before. This seems to work:
    outStr = "";
    newLine = "";
    function txtp() {
    outStr += newLine;
    newLine = splt[i];
    }else{
    newLine += splt[i];
    outStr += newLine;
    return outStr;
    .setFont(iterator)
    .setText(txtp())
  • Cricket Collins
    July 8, 2025 at 10:24 pm
    This worked perfectly! Thanks, I knew I was forgetting something simple.
  • Brie Clayton
    July 9, 2025 at 10:55 am
    Thanks for solving this, Dan!
