Activity › Forums › Adobe After Effects › sequencing stills
sequencing stills
Posted by Glen Jennings on April 14, 2010 at 6:11 amI have a series of still images taken from a time lapse camera and I want to create a sequence of them. What is the best way to do this?
Glen Jennings replied 16 years, 4 months ago 4 Members · 6 Replies -
Andy Steele
April 14, 2010 at 6:43 amWatch this tut – in the middle of it, Rob shows you exactly how to sequence a bunch of images. He uses the technique to create a custom particle but take out the particular stuff and you’ve got your answer.
https://library.creativecow.net/articles/birnholz_rob/red_giant_3d_montage.php
Interactive Lead
Cisco – Collaboration Software Group
https://webex.com/ -
Tudor “ted” jelescu
April 14, 2010 at 9:00 amImport sequence
Enable time remapping
Enable frame blending
Move keyframes to desired lengthTudor “Ted” Jelescu
Senior VFX Artist
Bucharest, Romania
http://www.ennstudio.ro -
Glen Jennings
April 14, 2010 at 9:03 amre:Import sequence
How does one import a sequence when what I have are folders of JPGs?
Tudor “ted” jelescu
April 14, 2010 at 9:26 amUsually the JPGs are numbered files- that will allow you to import them as a sequence by checking that option in the import window.
If you have your JPGs in several folders, import them as separate sequences, put them together in the proper order and nest them in a comp, then apply what I previously suggested.Tudor “Ted” Jelescu
Senior VFX Artist
Bucharest, Romania
Paul Minnaar
April 14, 2010 at 10:09 amAnother way I do it:
Import all your JPEGS, drag them all into the comp, then click animation/keyframe assistant/sequence layers – set the desired time length and vwala.
Glen Jennings
April 14, 2010 at 10:28 amCool thanks actually the jpeg sequence thing works well once you get the hang of it. The keyframe assistant way was how I originally tried and it gave me complications. Thanks for the input.
