Activity Forums Adobe Premiere Pro Sequences will not render or export
  • Sequences will not render or export
    Posted by Michael Clark on July 16, 2014 at 3:23 pm
    I have a brand new computer running Windows 8.1 and a trial of Premiere CC 2014. Video card is a GeForce GTX760 (not supported for CUDA). For the first couple of days I had it, the render and export was much slower than I anticipated for a computer with its specs, typically taking 10 times longer than the sequence length to export. I found online that you can change the cuda_supported_cards.txt file and add your videocard, thus giving you the ability to trick it into turning on acceleration. For the first day or two, it would scream through renders and exports to AME. Extremely fast – and worked fine in a number of different projects. Starting yesterday, however, regardless of the project I was in, it would no longer render or export. The clips with effects have effects ranging from Lumetri (which I’ve heard is quirky) to Neat Video Noise Reduction, to Mercalli stabilizer, to Magic Bullet Looks. Regardless of which effect was applied, it would not render. It says rendering, but would not begin the first frame of rendering. I have tried the following: deleting preview files, copying to a new sequence, importing to a new project, and most importantly, disabling CUDA. Not a single project will render or export. Any suggestions on what might be causing this?
    Edit: I revised the cuda_supported_cards.txt file and deleted the videocard from the list altogether, which seems to have fixed the problem. Is there any chance that Adobe will release an update that will support my card, or will I never be able to use acceleration?
    Ericbowen replied 12 years, 1 month ago 5 Members · 6 Replies
