Activity Forums Apple Final Cut Pro Sequences Settings for Blu-ray Share
  • Sequences Settings for Blu-ray Share
    Posted by David Mayer on November 4, 2016 at 6:45 pm
    My Share to Blu-ray keeps stopping at 66%.
    So I exported my project as a ProRes 422, Linear PCM file
    and tried sharing that as a new Project to Blu-ray, instead.
    For that one, my sequence settings are:
    1080i HD
    1920 x 1080
    29.97i
    Stereo 48kHz
    Should I try different sequence settings or do I need to
    trouble shoot the problem elsewhere?
    iMac (Retina 5K, 27 inch, Late 2015)
    4 GHz Intel Core i7
    16 GB 1867 MHz DDR3
    OS X 10.11.6
    Final Cut Pro X (10.2.3)
    Canon C100
    Mark Suszko replied 9 years, 10 months ago 3 Members · 3 Replies
  • Mark Suszko
    November 4, 2016 at 7:42 pm
    Are you saving it to the hard drive, then burning it using Compressor, or burning straight to BD-ROM? I have a devil of a time making my BD-Rom dubs, seems like mine poop out at around the 60 percent mark as well. I have to take steps to make sure there is enough free space in the imac and the RAID to contain the image, pre-burn, and that the imac doesn’t change the targeted burner or drive. Even when it works, it can take all day to make two dubs this way.
  • Lori Murphy
    November 5, 2016 at 3:27 am
    I’m having the same issue. It’s maddening! Trying to burn for a client deadline. Would love a solution!
  • Mark Suszko
    November 5, 2016 at 5:06 am
    Try rendering to the hard drive first, then burning a disk image.
