Activity Forums Video Copilot Sequenceing layers for slideshow
  • Sequenceing layers for slideshow
    Posted by Sam Oliver on April 29, 2008 at 12:11 am
    Hello I have been going through this tutorial and I did it fine the first time now I am getting stuck every time. https://library.creativecow.net/articles/kramer_andrew/slideshows/video-tutorial.php
    I went trough the tutorial fine and made a slide show without any problems. I then tried to go back and make another one and now I cant get the Key Frame Assistant/Sequence Layers, to work right,it will Sequence them with out the overlap but it will not do it if I select Overlap. I have went back and checked all my settings but everything seems to be the same. I have went back step by step with the tutorial but I am still clueless as to what the problem could be. I am using AE 7.0
    Sam Oliver replied 18 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
