Activity › Forums › Adobe After Effects › Sequenced render via Media Encoder
  • Sequenced render via Media Encoder
    Posted by Max Luczynski on August 18, 2019 at 7:52 pm
    My issue is this:
    I build a lot of animations for Instagram Stories,
    which are very often broken down into multiple sequences,
    with a fixed maximum length of 15 seconds,
    But may also be shorter depending on whats shown.
    I usually build a complete Instagram story in one composition,
    But for rendering I have to go in and adjust
    the work area by hand to the x sequences I want to be output
    to be uploaded to instagram, which is especially tedious
    when the client likes to do adjustments and the whole Instagram
    Story has to be re-rendered into the same or adjusted sequences.
    I am aware that i could make x „render compositions“ that contain my main composition but just show a specific sequence of it but this system is prone to error should one of the sequences become shorter / longer in the course of client iterations.
    I just wondered if there might be an intelligent, maybe marker-based solution to „cut up“ a composition for rendering it into multiple sequences, ideally in adobe media encoder.
    Max Luczynski replied 7 years, 1 month ago 3 Members · 3 Replies
