Activity › Forums › Apple Final Cut Pro Legacy › Sequence within sequence
  • Sequence within sequence
    Posted by Robin on September 26, 2005 at 1:45 am
    An issue arose through the HDV forum which I thought could be best posted here.
    Putting a sequence within a sequence in FCP causes instability and a whole lot of crashing.
    Why?
    Is there a method to make it workable?
    I got it to work finally, but it involved saving every change and a lot of restarting.
    Robin replied 21 years ago 3 Members · 3 Replies
  • Aiden
    September 26, 2005 at 1:51 am
    I don’t know if this was fixed in FCP5, but in 4.1 I ran into a problem with sound dropping out after Transitions, due to nesting sequences. My solution was to delete all of my render files before I was ready to “Print to tape”.
  • Thaxter Clavemarlton
    September 26, 2005 at 10:57 am
    [aiden] “I ran into a problem with sound dropping out after Transitions, due to nesting sequences.”
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
  • Robin
    September 26, 2005 at 3:22 pm
    thanks
