Activity Forums Apple Final Cut Pro Legacy Sequence Updates across Multiple users
  • Sequence Updates across Multiple users
    Posted by Mike Witting on July 12, 2007 at 8:53 pm
    Hello I am involved in a project which has different editors working on different aspects of the show at the same time(vfx editor, sound editor etc). outside of a custom xml script, does anyone know of a good way to automate a sequence update so when the lead editor makes changes to the show they don’t have to be manually replicated within the other editors projects? Otherwise I may just deal with matching cuts when they change or write an update script.
    s
    Mike Witting replied 19 years, 2 months ago 2 Members · 2 Replies
  • Walter Biscardi
    July 13, 2007 at 10:03 am
    I’m not sure of an automated way to do this since all the editors can’t all run the exact same project at the same time from a central location.
    What I would do is put a “holding project” somewhere centrally accessible for all the editors. When they finish a Sequence, the Editor opens that “holding project” and transfers their Sequence into that project. The other editors then open that “holding project” and transfer the Sequence into their projects.
    It’s as easy as dragging the Sequence from one project to the other. Then all the editors will have the exact same Sequences.
    What I would strongly recommend is to have your editors timestamp each version of the Sequences that go into the “holding project” so you’re sure everyone has the same Sequence. Such as “Sequence 1 11:45 7-14-07” Yes, FCP does create a “Date Modified” column entry for each version, but by timestamping the title of the Sequence, it’s much faster for the editors.
    There may be an automated way to do this, but I’ve not done it.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Mike Witting
    July 13, 2007 at 4:34 pm
    Thanks for the reply ….Each editor is working on their own copy of the master project uniquely named…just wanted to get around having to marry all the work manually..will look into a possible xml/apple event solution
    Thanks Again
