Activity › Forums › Apple Final Cut Pro Legacy › Sequence to Clips
Sequence to Clips
Posted by Martyn Morris on July 21, 2010 at 9:47 amHi there,
is there a way of splitting up a sequence into individual clips back in the browser?.
Thanks Martyn
Martyn Morris replied 16 years, 2 months ago 2 Members · 2 Replies -
Chris Guevarra
July 21, 2010 at 6:11 pmThis is a lengthy solution but you could try nesting the sequence and then export it into it’s own QT movie file then import it back into your project as you would any media and then break it down into subclips.
1) Nest the sequence
2) export it into a QT file
3) import it as a master clip
4) break it down into subclipsThanks,
Chris Guevarra
seekingasianfemale.com
massmovementtv.blogspot.com -
Martyn Morris
July 22, 2010 at 8:02 amThanks for the reply Chris.
That does sound like a lengthy solution but one that would work.
In the end I copied the clip from one sequence and insert paste (shift – V) in to an other.
Martyn.
