Activity › Forums › Apple Final Cut Pro Legacy › Sequence Timecode via firewire
Posted by Neil Sinclair on July 23, 2007 at 9:08 amCan somebody clarify a point for me?
Does FCP send sequence timecode (ie set to 10:00:00:00) via Firewire
on ANY deck?Regards
Russell Lasson replied 19 years, 1 month ago 5 Members · 5 Replies -
Paul Dickin
July 23, 2007 at 10:37 amHi
FCP 3 did, but apparantly only to Sony FW decks, not to those from other manufacturers.
So to rectify this anomaly from FCP 4 onwards this ‘feature’ has been elininated.Other software will do so, the one used by most folks here is Apple’s developer application SimpleVideoOut:
https://developer.apple.com/samplecode/SimpleVideoOut/index.htmlThe instructions, from Shane Ross, for using a DSR-11 (or DSR-25 etc) are normally here:
https://proapptips.com/tips/
article.php?story=2005092107133358&mode=print
but today I’ve had to retrieve them out of google’s not-cow-friendly cache: -
Nick Meyers
July 23, 2007 at 2:32 pmin a discussion we had a while back,
Shane mentioned that he found the output of SVO a tad over-blown.maybe that;s why he moved the post you mentioned?
Shane has also advised using SVO to output some Black with appropriate code (in this case 10Hr code)
then try an assemble edit to tape.
good luck with FW deck control on that.
i could never get it to work,
but Jude Cotter swears by it.Shane, Jude, Me…hey, this is a regular lafcpug party i’m having here on my own 🙂
nick
Russell Lasson
July 23, 2007 at 3:51 pmIf you’re trying to stripe a tape via FCP over firewire, I don’t think it works.
I have to set a timecode preset on the deck and then start recording. Once I have the basic timecode on the tape, I change the deck back to regen timecode. This will allow me to start a master at a specific timecode on the tape.
-Russ
Shane Ross
July 23, 2007 at 4:20 pmShane happens to have the process in a sticky that he can cut and paste…Uh oh…talking about myself in the third person…bad sign.
TC to DSR-11
Since FCP 4 we have been unable to stripe a new TC such as 00:58:00:00 or 01:58:00:00 to a DVCAM tape with the DSR-11. NO MORE!! I think I found a solution.
Get SimpleVideoOut from the Apple (its free):
https://developer.apple.com/samplecode/SimpleVideoOut/SimpleVideoOut.html
Then create a QT Movie in FCP or Xpress Pro from a sequence which has the starting TC you want on the tape. I just tried it with 00:58:00:00. In the timeline, I just put Bars & Tone for 90 seconds and a black slug for 45 (to take me over 01:00:00:00). You could create a sequence with whatever combination you wanted with the TC set to start at whatever timecode you need for your choice. But the Timeline TC MUST be set to your desired starting code. The exported QT file will have this TC in it.
Then load this DV QT movie into SimpleVideoOut (having selecting Firewire / Apple Firewire PAL or NTSC when you open the app).
Now load a fresh DVCAM tape and set your DSR-11 to:
REC MODE = DVCAM
DV IN TC = EXTERNAL(Have the TC display turned on for this first test so you can verify it has worked.)
Then just hold the REC and PLAY buttons together on the DSR-11 and press play in the SimpleVideoOut app and the new TC will be recorded to your DVCAM tape. Hey presto you are now able to stripe a tape with what ever timecode you want using a DSR-11.
Remember to turn ‘DV IN TC’ back to INTERNAL on the DSR-11 when you come to record your edit to tape.
The problem with the DSR-11 is that it is not the best deck and starting recording at the exact TC, but playing with the pre-rolls should eventually get it spot on. I have had some success with FCP’s ‘Edit to Tape’ and very good results with Avid Xpress Pro after a few tweaks.
Also, if you just had a black QT file, you can change the starting TC to suite the tape; i.e. 00:58:00:00 or 02:58:00:00 etc without going back into FCP or Xpress Pro and rendering out another QT. To do this, just use Sebsky Tools to alter the starting TC of the file.
https://www.dharmafilm.com/sebskytools/Shane
Littlefrog Post
http://www.lfhd.net
