Activity Forums Apple Final Cut Pro Legacy Sequence shows as white in Canvas
  • Sequence shows as white in Canvas
    Posted by Terence Lyons on April 25, 2012 at 4:34 pm
    I have imported QT movie into my project and have dropped it down into the timeline. When I scrub through it, nothing shows in the Canvas though with Audio Scrubbing set to On there is sound. If I play forward by hitting the “L” key, the movie does show in the Canvas. If it makes a difference, View/Video Playback is set to: Digital Cinema Desktop Preview – Main.
    What should I do?
    Kylee Pena replied 14 years, 4 months ago 4 Members · 5 Replies
  • Kylee Pena
    April 25, 2012 at 8:01 pm
    What is your sequence setting, and the codec of your QT movie?
  • Terry Lyons
    April 25, 2012 at 9:40 pm
    Kylee,
    The properties of the .mov file are: Apple ProRes 422,
    Linear PCM, Timecode
    1920 x 1080
    The sequence settings in FCP are:
    Frame Size: 1920 x 1080 HDTV 1080i(16:9)
    Pixel Aspect: Square
    Quicktime Video Settings/Compressor: Apple ProRes 422
    Terence Lyons
    web/multimedia/photography
  • Shane Ross
    April 26, 2012 at 2:18 pm
    #15 White or Black Canvas or Viewer
    Shane’s Stock Answer #15: White or Black Canvas or Viewer
    Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
    OR…
    Click on the drop down menu above the Viewer or Canvas and make sure that you are on IMAGE or IMAGE + WIREFRAME.
    Shane
    Little Frog Post
  • Terry Lyons
    April 26, 2012 at 3:34 pm
    Shane,
    “VIEW>CHANNELS and set it to RGB” did the trick! Thanks so much!
    Now, how would I of had that set like that?
    Terence Lyons
  • Kylee Pena
    April 29, 2012 at 11:22 pm
    You probably accidentally hit a keyboard shortcut. I think that one is shift-W?
