Activity › Forums › Adobe Premiere Pro › Sequence settings with Sony PXW-X70 footage (XAVC)
  • Sequence settings with Sony PXW-X70 footage (XAVC)
    Posted by Christopher Pavsek on January 13, 2015 at 9:20 pm
    I’m confused about sequence settings to work with footage from a Sony PXW-X70, shot using the XAVC HD at 50mbps.
    If I create a sequence from the clip, I get the following:
    Can this be right? Is there no way to select the native codec for the footage?
    Working in Premiere Pro CC 2014 with latest update.
    g4dp867, 798mg RAM, FCP 3.02
    Jeff Pulera replied 11 years, 8 months ago 3 Members · 2 Replies
  • Ann Bens
    January 13, 2015 at 9:24 pm
    The settings are good.
    You dont want to select the native codec for preview. That will make it unworkeble.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Jeff Pulera
    January 14, 2015 at 3:05 pm
    What you need to be concerned about is that the frame size, frame rate, pixel aspect ratio, and field order (upper, lower, or progressive) of the sequence match the source footage, which it certainly ought to. So as Ann stated, all good. Don’t worry that it says “ARRI” at the top. You will find other presets such as AVCHD with the exact same settings as well, doesn’t matter as long as specs match footage.
    Jeff Pulera
    Safe Harbor Computers
