Activity Forums Apple Final Cut Pro Legacy Sequence settings size issue
  • Sequence settings size issue
    Posted by Nel Shelby on March 21, 2013 at 5:53 pm
    HI,
    I am using easy set up to set up an XDCAM project. I selected XDCAM HD 1080i60 VBR – then I create a new sequence and the sequence is 1440X1080 instead of 1920X1080. It won’t let me change the size in settings. Why is it doing this? I just trashed preferences thinking I may have checked something along the way. Any advice?
    Nel Shelby replied 13 years, 6 months ago 3 Members · 10 Replies
  • 10 Replies
  • Shane Ross
    March 21, 2013 at 5:58 pm
    That flavor of XDCAM is thin raster, or anamorphic. Meaning 1440×1080 squeezed. FCP unsqueezes it so you see it full screen.
    If you want a 1920×1080 timeline, use a ProRes 422 sequence setting and add your footage to that. You’ll get a green render bar, but you can work fine in real time with that.
    Shane
    Little Frog Post
  • Nel Shelby
    March 21, 2013 at 6:53 pm
    Thanks so much.
    I have always set my easy set up as XDCAM and item properties always says 1920X1080, so not sure why it does not anymore. I also just dropped the files in a sequence and it asked if I wanted to match the video settings and when I said yes, item properties showed 1920X1080.
  • Shane Ross
    March 21, 2013 at 7:06 pm
    Then there you go. You have the format of XDCAM that is 1920×1080. Lower data rate versions are 1440×1080.
    You are good to go.
    Shane
    Little Frog Post
  • Nel Shelby
    March 21, 2013 at 7:19 pm
    good to go but now to tackle the big issue compressor keeps failing while outputting a few of my projects to DVD. It says Quick time error 0 or -50.
    I thought it was my SXS cards or maybe something happened in log and transfer.
    I saved all my BPAV folders and have re-logged footage and still it fails. Any ideas – I probably need to give more info, but I am exhausted from trouble shooting for a few weeks now.
  • Shane Ross
    March 21, 2013 at 7:25 pm
    Change the sequence Compressor to ProRes. Render…export a self contained QT file…and try to author the DVD with that.
    Shane
    Little Frog Post
  • Nel Shelby
    March 21, 2013 at 7:29 pm
    Great I will try that. I have done all of that accept author it somewhere else, so hoping that works…I will report back!
  • Joseph Owens
    March 22, 2013 at 6:15 pm
    [Nel Shelby] ” big issue compressor keeps failing while outputting a few of my projects to DVD. It says Quick time error 0 or -50.”
    My bet would be that Quicktime has problems with ProRes coded files with synthetic resolutions that are quasi-custom, not standard (square) size. ProRes really wants to be square, but only in orthodox resolutions like 1920×1080 or 720×480, and your 1440 “stretch” may be confusing the decoder. Certainly this happened when I tried some 853×480 ProRes. FCP7 just went crazy.
    jPo
    “I always pass on free advice — its never of any use to me” Oscar Wilde.
  • Nel Shelby
    March 23, 2013 at 3:49 am
    I finally got everything to work changing compressor to pro res, exporting a self contained QT file out of FCP and then encoding in DVDSP. THANK YOU
    Although still getting general error when I render at times.
    Joseph that makes sense about the decoder being confused, but I am still getting a general error when rendering. I can tell there is a real problem but I have not gotten to the bottom of it yet. Thanks so much
  • Joseph Owens
    March 23, 2013 at 5:18 pm
    [Nel Shelby] ” I am still getting a general error when rendering.”
    Yeah, I am actually sitting here looking at more or less the same thing. I have a ProRes4444 2048×1152 timeline that “renders” okay on the timeline, but as soon as I want to export a QT movie in PR4444, it balks and gives me a General Error, but if I choose PR422HQ, it goes.
    Thanks, Apple.
    jPo
  • Nel Shelby
    March 24, 2013 at 6:54 pm
    Pretty sure I figured it out. I got a new server installed and it runs through my office on CAT5 cable. I’m only have problems with the videos I have logged over that cable. So duh I need to log and transfer to my internal drives. I tried to re log footage last night and it compressed fine when I loaded it on my desktop. Hope this is it for all my issues!!
