Activity Forums Apple Final Cut Pro Legacy Sequence settings question
  • Sequence settings question
    Posted by Jack Pitzer on May 2, 2005 at 7:16 pm
    I’m working on a project for a client, which is a synchronized presentation, that has a talking head shot of a Dr. synced with
    Power point slides. The background is a TIFF, as are the slides.
    The presenter video is DVC Pro compression, as is the sequence setting.
    My problem is that the slides look a bit “soft/fuzzy”
    I’ve been playing with different sequence compression settings.
    Does anybody have a recommendation for the best codec to use for this.
    Also, does the sequence setting affect how the video looks after I output it to MPEG 2 via compressor?
    The final project will be a DVD.
    Thanks much in advance!
    Jack Pitzer replied 21 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
