Activity Forums Apple Final Cut Pro Legacy Sequence Settings Primer ?
  • Sequence Settings Primer ?
    Posted by Dennis Dean on November 3, 2010 at 9:49 pm
    Can anyone point me to a good primer or quick start guide to understanding the relationship between Frame Size Aspect Ratio, Pixel Aspect Ratios and Compressor settings?
    It’s simple enough when all I need to do is create a sequence when all of the video matches, but what do you use when the actual video you are using is a small part of the project, and you’d like it to be in an HD format but aren’t sure what to choose? For example, what’s the dif between HDTV and HD? When should I use Apple Pro Res 422 and when should I choose something else?
    I’m hoping to find something simpler and smaller than the manual… but I’ll be perusing those tonight.
    Is there a tutorial on Cow that will help?
    I’m running a MacBook Pro Intel Core Duo at 2.2 Ghz 2 Gig of Ram, video is on a second internal drive.
    Dennis Dean
    The Dean Group
    -It’s about results-
    http://www.deangroup.com
    Dennis Dean replied 15 years, 10 months ago 2 Members · 2 Replies
  • David Battistella
    November 4, 2010 at 12:43 pm
    Denis,
    As far as I know there is no tutorial on this.
    Basically FCP is set up to do anything you want. First determine what you want your deliverable to be and then work backward from there.
    There are codecs that are better than others.
    FOR HD VIDEO a good start would be:
    1920x 1080 square pixels (23.98) (29.97) depending on what your acquisition format is.
    Apple Prores 422 HQ
    You might be best to have someone in your local community come in and set some presets for you and save yourself a lot of time and aggravation.
    David
    Peace
  • Dennis Dean
    November 5, 2010 at 1:09 am
    Dave – thanks very much. Good idea ! and thanks for the starting point –
    DD
    Dennis Dean
    The Dean Group
