Activity Forums Sony Cameras Sequence settings for sony ex1 /FCP6
  • Sequence settings for sony ex1 /FCP6
    Posted by Mark Huckle on August 7, 2008 at 10:10 am
    I just want to check that I have the right sequence settings in FCP before I start my next edit. I’ve ingested the Sony EX1 SxS card using XDCAM transfer and I’m ready to take clips from the browser to the timeline.
    I filmed 1080p (25 framerate) HQ and want to edit in HD before downconverting prior to outputting and exporting.
    The compressor settings at the bottom are straightforward from my easy setup (Ex 1080p (25…)
    Field dominance is none
    Square pixel ratio ?
    Framesize 1920×1080?
    Aspect ratio ?? – HDTV 1080I?
    The last three I would appreciate some guidance on. The last two appear to be the closest preset.
    Many thanks in anticipation
    Craig Seeman replied 18 years, 1 month ago 2 Members · 1 Reply
  • Craig Seeman
    August 7, 2008 at 1:33 pm
    Why not use the 1080p25 XDCAM EX Easy Setup?
    I select the Easy Setup and change Render to Apple ProRez to avoid the GOP conform.
