Sequence settings for slideshow… Quetion about codecs… 8 bit, 10 bit uncompressed?
I’m creating a slideshow of still pics – mostly jpegs.
I’ve got a question about the sequence settings. If I open the sequence settings, There is a “Quicktime Video Settings” – and the compressor is set to DV/DVCPRO – NTSC.
My question is, is there a better setting for what I’m working with here – still pics? I’m going to output using compressor to DVD when it’s done.
Also, when I’m working with mini-dv footage, should I use a different compressor? I’ve heard that using the uncompressed 8 bit or 10 bit is better for working with graphics.
Can anyone explain this to me? I’m confused about all of these different codes in the sequence settings, and how they will affect my footage.
DamonDamon Hoydysh
https://www.comicdisobedience.com
damon@highlinestudios.com
